U-boat capsoil....
7.6K views 28 replies 20 participants last post by  Bonzodog
I came across this today and I think I like it . I have never handled a u-boat watch but I know they are on the large side although this at 44mm is about acceptable. I really like the how the dial looks through the oil. Has anyone got an oil filled watch or a U-boat who can comment [emoji106]
https://www.keepthetime.com/blog/u-boat-capsoil-darkmoon-oil-filled-watches/
Sent from my iPhone using Tapatalk
#5 ·
An interesting concept, a bit macho but................. G-Shock. :wink:
#7 ·
Like a lot of things when did they get so expensive.
:huh:
I had this 53mm one for years, never had any problems, they aren't for everyone but it was a well made and finished watch and came with two good quality leather straps.
images?q=tbn:ANd9GcQcW064sW68RyuuNLF3T1o
The oil filled one looks okay but doesn't have their trademark crown which is sort of part of the attraction.
#16 ·
I got one and love the bubble. It is a great conversation piece and fun to look at. However, the battery replacement is an issue and costs quite a bit becauseyou have to send it out to certified UBoat repair shop. Pros and cons as with every watch. I would suggest seeing and wearing one in person if you can. That is really the only way to understand how it wears and what you think of the bubble.
#19 ·
Interesting idea. The bubble in the oil is clearly a conversation starter, as they could get rid of it but choose not to. The bubble is the only thing that shows that there is some kind of fluid there. Presumably the hands can get through the bubble's surface tension without slowing down?
#21 · (Edited by Moderator)
I did wonder if the bubble is there to cater for coefficient of thermal expansion of the oil between 0 and 50 deg C and stop it pushing out the crystal. I cant think why else except novelty why they would leave a bubble in the oil.
Quite like the red version but at cÂŁ900 it's too expensive. They do appear to have solved the battery change problem with quick change coin access.
#20 · (Edited by Moderator)
Not for me at all I'm afraid :( As far as I'm aware Sinn are the only other manufacturer of an oil filled watch. I remember watching a video of someone filling there Casio (possibly a G-Shock) with oil. It made the display clearer & the watch worked fine afterwards - so maybe you make your own?? Not sure what sort of oil to use - silicone maybe?
Another one - there are loads (probably):
Ressence Type 5 | Diving Watches | Ressence (ressencewatches.com)
More - not exactly in depth - research reveals these interesting (or not) facts about oil filled watches:
Oil filling is done for three reasons:
Depth rating. A fluid filled watch is basically incompressible and has a near infinite depth rating. The pressure equalizes inside so the case is never stressed. It will work until the electronics/battery crush themselves which is really deep.
Readability. Many watches can't be read past a certain angle, especially under water. Sort of like the viewing angle. Oil filled watches can be read nearly a full 180 degrees across the face.
It looks cool. It's like a perfect AR coating. It's like the hands are moving magically inside of a solid piece of crystal.
#23 ·
It seems to me that the designers of oil filled quartz miss the trick of designing the watch with an external battery.
We could see a 'Swatch type' caseback holding the battery with little to no need of ever opening the body of the watch.
Alternatively they should look towards phone manufacturing with rechargeable wireless technology for a simple 6 months recharge cycle using common phone recharge devices.
I like them but refuse to tackle the stress of battery refitting.
#27 ·
I saw a photo of a later model with 2 quick change battery compartments (coin to open)on the back plate.
