Hi all,
I've also posted on a well known Seiko forum, but thought I'd try a post here for any further thoughts and to assist others at a later date.
I have aquired this Seiko Chrono with original bracelet. It is due for a service, new crystal and probably bezel insert via Steve at Rytetime, but there are a few questions that I am once again turning to you for some help.
The ? original box states Prospex, is this correct?
1. The caseback states Y182-6F00 with a serial of 270210 ? July 1992 or 2002, but the movement is a 7T32B, I had expected the Y182 to the the movement after a bit of research, but it arrived to be the 7T32B, is this correct. The caseback looks as if had never been off, so I'm hoping not a replacement movement. I thought the Y182 was the movement but suprised to see the 7T32B inside.
2. Cant seem to set the alarm after reading the instructions, goes through all the setting steps, but continually rings when it should be silent to allow setting of the alarm.
Thanks as always
All the best, Rich.
Thanks as always
All the best, Rich.
