Help with Ronda 715 quartz movement
8.5K views 5 replies 2 participants last post by  pauluspaolo
Hello
I have just bought a replacement Ronda 715 movement to fit in a Traser 200m diver case. This came with an utterly cream crackered movement hence the replacement. I need to remove the stem from the new movement so I can fit the stem and crown that came with the Traser. Can someone please tell me how to do this? I know that some automatics have a recess which when pressed releases the stem. Does the quartz have a similar arrangement?
Thanks for any help.
Paul
#6 ·
Just thought I'd update this post. I've found both hands and crystal that will fit so the watch is now complete and working. Doesn't look too bad either (don't have a digital camera sorry, otherwise I'd try and show you it), all it needs now is a strap and I can start to wear it.
Many thanks to Foggy for the case and much needed information and advice.
Paul
