Whatever you do don't cut slots!!
The screws screw into a hollow tube which is fixed into the opposite link (with the flat ends)
Sometimes the screws don't fall out when unscrewed and you have to separate the links i.e. pull the link with the flat end away from the centre link whilst holding the link with the screws between thumb and forefinger :lol:
I have had many happy hours with tricky B'ling bracelets
by the way this version of the B'ling bracelet is a bit odd to adjust because of the angled links you really have to imagine the position of the tubes holding the links together because they don't go through the links parallel to the angle they go through the bracelet at 90 degrees to the edge of the bracelet ... good luck
