Longines 25.17 movement - Crown hard to pull
69 views 10 replies 5 participants last post by  SQ-whiff
Hello,
I've an old Longines equipped with a 25.17 caliber and it's difficult to pull the crown to set the time. I guess there is something wrong with the yoke, or setting lever or setting lever spring, but I don't know what to do. Maybe I will have to file gently the tip of the spring? See part in green on the photo.
Am I right?
#4 ·
Thank you, but I've done that already. It looks like there is too much tension in the stem of the spring; it's a little curved (see yellow part). I will disassemble these part again and replace them.
#5 ·
Ah, right. Personally, I don't think there looks to be too much tension in that spring. It needs to be under tension so that it drops down when the crown is pulled out. The main resistance when pulling out the crown will come from the circled contact area in the following pic:
So if I had your issue, I would concentrate on these surfaces, making sure they are nice and smooth, possibly polishing, not sanding the surfaces with a very very fine grit wet and dry followed with some thicker grease.
