Acrylic Polish Pictorial
98 replies to this topic
#1 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
  • Interests:mainly milf really
Posted 02 February 2005 - 09:56 PM
I was polishing up an acrylic and I thought I’d do a picture story to show how I do it. Most of you regulars will probably have similar methods but I thought it might be useful for newbies and lurkers.
The watch to be fettled is the boys Timex non date that Neil sourced for me.
In the Beginning
user posted image
I start by looking in which direction the majority of scratches run, you want to start by going across the scratches as much as possible. DO NOT GO IN CIRCLES. Looking at this watch the best direction that goes across most of the scratches looks to be from 8 to 2.
So very carefully, taking care not to scratch the bezel or case, take a small piece of 400 grade wet and dry paper, use it dry and gently rub back and forth in the chosen direction. Every 10 seconds or so stop, rub off the dust with your thumb and check to see if you need to go deeper, you want a nice even sanding across the whole crystal so no scratches are visible. Sometimes you will see deeper nicks as they stand out white (like at 1 below).
user posted image
If this is the case then go a little further on that spot until it has gone. On domed crystals you may have to run the wet and dry around the edge to remove scratches.
Once you have a nice even finish you need to move up to 1200 grade wet and dry. Sand at 90 degrees to the direction you used the 400 so in this case from 11 to 5. This shouldn’t take long, again use your thumb to remove the dust and check for a nice even sanding.
user posted image
#2 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
Posted 02 February 2005 - 09:58 PM
Now to polish.
I use good old household Brasso and a Vileda cloth folded twice on itself (so it’s 4 layers thick).
Place the cloth on a hard level surface and pour a small amount of Brasso in the middle.
Now place the watch face down in the Brasso and vigorously rub back and forth (again no circles).
There is no need to press the watch hard down into the cloth, in fact you could crack the crystal doing this so just keep a light pressure and nice and fast back and forth. The fast rubbing actually melts the surface of the acrylic which is what gives it such an even polish when finished.
Pay particular attention to the edges, you may have to move the watch to an angle of 45 degrees to do this. Keep going all over, as long as you go back and forth you can go in all directions, i.e. 12 to 6, 9 to 3 etc until it’s had a good polish up. Then get a dry cloth and rub away the left over Brasso and you should have a nicely polished good as new crystal.
The finished crystal
this picture isn't the best as I've taken it under artificial light but it shows how good the polishing is. YES IT IS THE SAME WATCH!
Hope this has been of help.
#3 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
Posted 02 February 2005 - 10:01 PM
user posted image
#4 OFFLINE   jasonm
    Equation of Time
  • Moderator
  • 23,317 posts
  • Joined 22-November 03
  • Interests:Anything with a pulse....
Posted 02 February 2005 - 10:03 PM
#5 OFFLINE   ESL
    Minute Repeater
  • Member*
  • 3,560 posts
  • Joined 27-January 04
Nice post PG.
#6 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
Posted 02 February 2005 - 10:10 PM
QUOTE(ESL @ Feb 2 2005, 10:03 PM)
Nice post PG.
View Post
I remember the 1st time I did it george after reading about this method. Though Oh my god what have I done, but once you've done a couple you get a feel for it and can knock em out in a few minutes.
Mineral grystals are possible (as Bry has shown) but take a hell of a lot more sanding and elbow grease!
#7 OFFLINE   Stan
    Equation of Time
  • Retired Moderator
  • 15,787 posts
  • Joined 07-August 03
Posted 02 February 2005 - 10:24 PM
I discovered Mer is good for a final buff up today after polishing me G10 crystals.
It's safe on plastic, at least that's what it said on the bottle. laugh.gif laugh.gif
#8 OFFLINE   hakim
    Chronograph
  • 1,292 posts
  • Joined 13-September 04
Posted 03 February 2005 - 09:45 AM
Great post PG. Thanks!
#9 Guest_neil_*
  • Guests
  • Joined --
Posted 03 February 2005 - 12:04 PM
Top man PG!
Fantastic job on the Timex.
That will be an invaluable resource for newbies and even many old hands. smile.gif
#10 OFFLINE   Roy
    Administrator
  • Admin
  • 14,128 posts
  • Joined 23-February 03
#11 OFFLINE   bry1975
    Minute Repeater
  • 3,325 posts
  • Joined 06-February 04
Posted 03 February 2005 - 12:44 PM
Have you polished any mineral lenses, the first one for me was Torture sad.gif
Regards
Bry
QUOTE(Roy @ Feb 3 2005, 12:04 PM)
View Post
#12 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
Posted 03 February 2005 - 12:47 PM
I've done a couple of minerals Bry (didn't I show you that Richo qtz?) but as you say torture. Have to be flat (don't even attempt a domed one) and lots and lots of back and forth. Might be easier on a belt sander but I'm not that brave and I never did get a perfect finish.
#13 OFFLINE   Mal52
    Chronograph
  • 1,253 posts
  • Joined 07-October 03
  • Interests:Watches/Photography
Posted 03 February 2005 - 12:57 PM
Top Tip PG
Great result
Cheers Mal
#14 OFFLINE   bry1975
    Minute Repeater
  • 3,325 posts
Posted 03 February 2005 - 01:18 PM
Paul,
I didn't know you refurbed the Ricoh. Did you use Ce02 to polish the mineral? Domed crystals aint to bad actually, just gotta use machine power:D
How is the Ricoh for accuracy, bet it keeps good time?
Regards
Bry
#15 OFFLINE   pg tips
    Equation of Time
  • Retired Moderator
  • 18,651 posts
  • Joined 16-May 03
Posted 03 February 2005 - 01:20 PM
Just an add on if you get just the one scratch you don't have to go over the whole crystal with the Wet and Dry, Just sand at rightangles to the scratch, if it's not too deep you can get away with just the 1200.
Then use the brasso. I've not tried Mer Stan but like every member of the male population over a certain age I have some in the garage somewhere so I'll give it a try.
Polywatch is very good if you just want to give it a quick buff up if it's dulled down a bit. It will not remove deep scratches on it's own though. Roy is the cheapest supplier of polywatch in the world, I think!
