Sekonda Day Date
2 replies to this topic
#1 OFFLINE   ETCHY
    Chronograph
  • 1,021 posts
  • Joined 03-August 04
Posted 07 March 2010 - 01:54 PM
Hello
I have an incoming 70's/ 80's Sekonda Automatic day/date with the starburst type case. I believe these have a Slava movement.
It has a small button in addition to the crown for changing (I think) the day.
Can anyone advise how this button stuff works? How do I change the day & date? Do I have to pull the crown out before pressing the button or can I do it at anytime?
Help would be appreciated as when it gets here I don't want to knacker it by doing the wrong thing :shocking:
Any general info' on these watches would also be interesting :wink:
Dave
#2 OFFLINE   mel
    Perpetual Calendar
  • Member*
  • 9,092 posts
  • Joined 06-December 06
Posted 07 March 2010 - 03:37 PM
I've done this answer a few times now, but yes, the button is a quick change on the date only. You use a stylus or fingernail to push this in and the date should change as the button is released. A common fault is the button sticks through lack of use so it's a good idea to exercise it now and then by using it to set the date manually!. :yes:
The day set is done by pulling out the crwon and turning - it's NOT a quickset so you have to work through the twenty four hours to get in to go over - but of course the date also goes over at midnight! :eek:
The easiest way to set day date and time on these is to use the day and time set first - so, pull out the crown and wind to correct day and then time, remembering to allow for going through mid-day if you are doing this PM. Then use the pusher to set the date to the correct one. SEEMPLES (we need a meerkat icon! :lol:)
HTH a bit. Good reliable Slava movements. :yes:
SLAVA Medical Watch
where the pusher is incised into the side so it cannot be seen from the front - same movement and setting procedure.
#3 OFFLINE   ETCHY
    Chronograph
  • 1,021 posts
Posted 07 March 2010 - 04:48 PM
That's great, cheers for the advice & help Mel :thumbsup:
I like that Slava a lot !
Many thanks
Dave
