The Watch Forum: Fitting New Winding Stem - The Watch Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   BillD
  • Pin Pallet
  • Icon
  • Group: New Member
Posted 19 February 2009 - 05:10 PM
Hi All,
In a follow up from my last posing I have now received the winding stem for the Carley & Clemence Military Watch. I had to drill out and tap the crown as the old stem had broken off at the base. All well and good I thought as this procedure went very well indeed. However, when l I tried to put the new stem into the watch it 'clicked' into place very readily but the watch will not wind or can I change the hands etc. WHAT HAVE I DONE WRONG. The old stem may have been in the 'hands setting' position when I removed to old stem.
Any thoughts anyone? Any help much appreciated.
Maybe I should say that I did check the new and old stem against each other to check dimensions etc and both look identical. I can't even get the old stem to work either.
Regards
BillD
This post has been edited by BillD: 19 February 2009 - 05:13 PM
#2 User is offline   pg tips
  • 35 Jewel
  • Icon
  • Group: Moderator
  • Interests:mainly milf really
Posted 19 February 2009 - 08:47 PM
QUOTE (BillD @ Feb 19 2009, 05:10 PM) <{POST_SNAPBACK}>
Hi All,
Regards
BillD
Perhaps you haven't done anything wrong. It could be the old stem snapped because something in the movement seized and someone tried to force it and broke the stem?
The fault you describe could be a number of reasons. It may have to go to an expert.
Kindest regards from Paul G. Remember they are ONLY watches and this is JUST a forum. CHILL OUT! If I was asked what one piece of advice I could give a "newbie" to the forum it would be to ensure you read all of MarkF's posts (except when it comes to Sci-Fi).
This forum is owned and paid for by Roy Taylor of RLTwatches.com. Please take time to rtfr (read the forum rules). Don't blame the mods if they zap your post because you didn't read the guidelines! If all you are after is a valuation then please introduce yourself 1st, and remember well, the engine of search, a friend it can be!
"There are, of course, many problems connected with life of which some of the most popular are, why are people born, why do they die and why do they spend so much of the intervening time wearing digital watches?" D.Adams
At least it's not like on the Sopranos where they cut to a black screen in mid sen
#3 Guest_Rabbit_*
  • Group: Guests
Posted 19 February 2009 - 08:50 PM
nono.gif Just comparing the stems side by side is not the way to do it . The stems should have been measured for length as well as the diameter. Also I think drilling out the stem and re-threading has caused more damage than good.
My policy is 'If your not sure about what you are doing then leave well alone'
That's my opinion anyway.
Rabbit
#4 User is offline   BillD
  • Pin Pallet
  • Icon
  • Group: New Member
Posted 20 February 2009 - 10:43 AM
Thanks for your replies. I would like to add that the old stem, although it was snapped off at the base of the crown, still worked OK as you could wind it and set the hands with a pair of needle nose pliers and it was very easy to remove. It just seems odd to me that now I cannot use either the new or old stems. The new stem was purchased as a NOS for the movement (Certina(Kurth) 260) and as I have said is identical to the old one. You have to put the stem into the movement to measure where to cut it off!!
I have been teaching myself watch repair from a course I purchased and have been practicing this last year or so and have sucessfully stripped and cleaned two key wound pocket watches. This is the first crown wind watch I have looked at and was hoping for a few tips as to how to get the stem seated correctly. There are always those little tips that are never documented in course manuals !! Surley replacing an identical stem cannot be that much of a problem.
If this forum does not cover aspects of repairing but just collecting I think I will have to try elsewhere.
Thanks again for your time and replies
Regards
BillD
#5 User is offline   pg tips
  • 35 Jewel
  • Icon
  • Group: Moderator
Posted 20 February 2009 - 11:14 AM
Ah I see now that it was working and now it isn't.
Sounds like you've got something jammed in the winding gear. It's virtually impossible to diagnose without actually physically seeing the watch.
#6 User is offline   squareleg
  • 21 Jewel
  • Icon
  • Group: Member
Posted 20 February 2009 - 11:16 AM
QUOTE (pg tips @ Feb 19 2009, 08:47 PM) <{POST_SNAPBACK}>
To be fair, Bill, I think the above is about the best advice you're going to get on this one, as I'm sure there are guys here who could answer your question but not without seeing the problem first hand. smile.gif
Edit: Paul said exactly the same thing whilst I was posting. Spooky. ph34r.gif
This post has been edited by squareleg: 20 February 2009 - 11:18 AM
Regards, Nick.
WARNING
• This post was typed in a pet-owning household (currently canine variety, but sometime feline).
• Cigarette smoke particulates may have been present at time of writing this post.
• This post may contain nuts.
#7 User is offline   BillD
  • Pin Pallet
  • Icon
  • Group: New Member
Posted 20 February 2009 - 04:34 PM
Thanks Paul & Nick. I appreciate it is often difficult to diagnose problems from a distance and without actually seeing the watch. I will endeavour to fix the problem (without breaking it!!). I have a local watch repairer I will call upon for advise.
I try not to be just a 'dabbler' and take great care and consideration before I attempt anything on any mechanical watch. I believe them to be something worth protecting and caring for but to learn you have to practice. I really do appreciate the time (no pun intended!), commitment and skill of past generations of watchmakers and repairers. It takes a lifetime to gather that knowledge and I know I will never attain that standard but I enjoy the challenge!!!
Regards
Bill
#8 User is offline   squareleg
  • 21 Jewel
  • Icon
  • Group: Member
Posted 20 February 2009 - 05:13 PM
QUOTE (BillD @ Feb 20 2009, 04:34 PM) <{POST_SNAPBACK}>
Regards
Bill
Bill - with that sort of attitude, you're more than half way there. Nice post and very best of luck with your studies! thumbsup.gif I had a similar experience when I did my City & Guilds in cabinet-making. Part of the thrill was the feeling of 'standing on the shoulders of great men' and learning skills handed down the generations - an overwhelming feeling of a 'link with the past'. The whole thing was enormously rewarding, great fun and when I finally got my certificate I was the happiest bunny in town! smile.gif
Regards, Nick.
WARNING
Page 1 of 1
1 User(s) are reading this topic
Top 50 Watches
