Omega Seamaster F300repair
20 replies to this topic
#1 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
  • Joined 12-August 05
Posted 16 September 2007 - 05:24 PM
Hi People
Is it worth buying an OMEGA SEAMASTER f300 for a possible repair, seller says it is humming after a new battery fitted. Help please. unsure.gif
Dave S
#2 OFFLINE   Silver Hawk
    35 Jewel
  • Member*
  • 9,443 posts
  • Joined 02-December 03
  • Interests:Horology, Vintage Motorcycles (restoration and riding).
Posted 16 September 2007 - 05:55 PM
Humming is certainly a good sign...it means the electronics are sound.
But it doesn't mean the mechanics are. Unfortunately, the index wheel could still be damaged, the index pawls could be bent and twisted etc, so it is still a risk.....but one that I have taken many times in the past.
If it is humming, has the seller indicated why it is not running? Can you ask him? Might he know?
#3 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 17 September 2007 - 08:14 PM
QUOTE(Silver Hawk @ Sep 16 2007, 06:55 PM) <{POST_SNAPBACK}>
Well, done the deed, hell mend me, I have bought the f300 will let you know what I find, I expect lots of help as it all your fault you lot, if it wasn't for this forum I would still be ignorant of the pain that watch collecting causes you (but I like it). biggrin.gif
Dave S
#4 OFFLINE   mjolnir
    25 Jewel
  • 3,362 posts
  • Joined 03-January 06
Posted 18 September 2007 - 08:46 AM
I think I had my eye on the same one. It was the one with all the papers to go with it wasn't it?
I decided not to bid since I would have no idea how to fix it.
Hope its easily sorted.
#5 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 24 September 2007 - 04:39 PM
It's arrived and it is humming, when I pull out the crown to the second point to adjust time the second hand turns while adjusting hours and minutes, is this usual, in adjusting the date it can adjust either way up or down, i can't see any obvious signs nothing broken, one clamp missing, what is the outer screw ring for on the back ? what to do next
Dave S
#6 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 24 September 2007 - 04:43 PM
Another two shots
Dave S
#7 OFFLINE   Silver Hawk
    35 Jewel
  • Member*
  • 9,443 posts
Posted 24 September 2007 - 05:26 PM
QUOTE(dave993cars @ Sep 24 2007, 05:39 PM) <{POST_SNAPBACK}>
Dave,
Normally, the second hand does not turn when adjusting the hands.
Do you have a 10x loupe? For starters, you need to look through the plates at the hole marked with the red arrow below....
You should see two tines with a rectangular jewel stone on the end of each; the tines should be straight, and the jewels should sit nicely on an index wheel...I could go on, but it gets worse....you really need to seek help.....
Paul
#8 OFFLINE   Who. Me?
    21 Jewel
  • 1,407 posts
  • Joined 12-January 07
Posted 24 September 2007 - 06:24 PM
That ring releases the bracelet. The watch is circular, with no lugs. The watch drops into the bracelet, and the ring secures it to the watch.
With regards the fault, Paul knows his stuff.
Humming is 'good' though. Most of the knackered F300s out there have damaged coils and don't hum so they can be picked up cheaper.
Humming and not running probably means that drive is not being transmitted properly from the tuning fork to the handset. Could be the fingers that push the Index Wheel round (the pawls or tines as Paul says above) the Index Wheel itself or the clutch.
It might be worth you grabbing a cheapo off ebay, sold as 'not humming', and finding an older local watchmaker who knows their way around these watches and can do a transplant.
Probably won't be cheap though.
I've got a Geneve F300 that doesn't hum and it (and a donor watch) are with a local jeweller for repair. £140.00 to switch the coils over (to maintain originality), and replace the crown and stem. Add to that the cost of the watch and the donor watch, and mine is proving to be a real money-pit. It is quite cool though. I'm itching to get it back.
Edited by Who. Me?, 24 September 2007 - 06:27 PM.
#9 OFFLINE   s67
    17 Jewel
  • 503 posts
  • Joined 04-May 06
Posted 24 September 2007 - 08:07 PM
I have 2 of those watches. One with day and date and one with just the date.
I also know a man who is an expert at fixing them. Not too expensive either.
If you PM me I will give details.
Also if that battery he put in is incorrect it may hum but not for long.
Martyn
#10 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 24 September 2007 - 08:34 PM
QUOTE(Silver Hawk @ Sep 24 2007, 06:26 PM) <{POST_SNAPBACK}>
Dave,
Paul
Hi Paul
Using a 10x loupe I can see two pins (shafts) but no wheel the pins are straight, there are two spring wires that are also visible, sounds like something missing ? ohmy.gif
Dave S
#11 OFFLINE   JonW
    35 Jewel
  • 9,213 posts
  • Joined 23-March 05
Posted 25 September 2007 - 09:43 AM
I also have one of these that hums and doesnt run... unless you tap it... then the secs sometimes run for a few secs, sometimes not at all...
#12 OFFLINE   pg tips
    35 Jewel
  • Moderator
  • 18,651 posts
  • Joined 16-May 03
  • Interests:mainly milf really
Posted 25 September 2007 - 08:56 PM
it's wizardry you know. you are dealing with forces beyond human comprehension!
#13 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 25 September 2007 - 08:58 PM
Paul
I have found a f300 with a 1260 movement not humming but mine is a 1250 movement are they compatible can I use the 1260 as a donor for the other, is it feasible to change the mechanical part across or is it better to let the professional to do the job.
Dave S
#14 OFFLINE   dave993cars
    15 Jewel
  • 236 posts
Posted 02 October 2007 - 09:02 PM
Hi People
I have decided to get help, further to the thread on the Bulova Accutron Spaceview I have contacted Keith and he has said it could be the clutch, with a worst case scenario price it looks like a no brainer to send it to him, so I have, will keep you all posted, thanks for all the help especially Paul.
Regards
Dave S
#15 OFFLINE   Nalu
    21 Jewel
  • 2,397 posts
  • Joined 28-November 03
  • Interests:Watches, rugby, music, photography, SCUBA
Posted 04 October 2007 - 03:15 AM
QUOTE(pg tips @ Sep 25 2007, 08:56 PM) <{POST_SNAPBACK}>
My thoughts exactly PG!
