Hi - with all the chopping and changing of my watches lately, I am finding I'm sopending a bit on having links removed. How do I do it myself. Latest arrival is a seiko 5 pepsi bezel with stainless bracelet. The links have an arrow showing a direction - What do I use to remove the link? Is there a special tool?
Thanks and sorry it is a bit of a numpty question - i tried the search field but had no luck.
Yes - you can buy a special tool - search on eBay etc.
Normally it's just a small plastic vice/ holder with a pin you push or wind through to push the pins through.
(Bit like a cycle chain link remover if you know what that is like)
Equally you put the strap flat and push the pins (same direction as the arrows) with anything small enough to fit up the hole. A small screwdriver or even a fine nail might not be elegant but should work fine.
A proper tool will cost a bit more but the risk of slipping and either scratching the watch or stabbing yourself in the hand should be less!
There are a couple of different types of Seiko bracelet , but i did google "removing links in a seiko bracelet" and it came up with a few sites which will no doubt have your type on .
Can't link to them as most are commercial sites in some way shape or form , but you will be able to get the necessary tools from the RLT sales section i believe.
Its not a difficult job once you have done a couple and have the right tools
cheers
Andy
Edit just had a look and Roy does a tool kit on here with the vice etc in it but its out of stock at the mo
I'm curious, I've got a little mettle & rubber mallet and pins and pin pushers that came with a cheap kit, with the strap in a vertical holder, is that appropriate for gently knocking out the split pin and pin & collar type link pins?
Craig, be care if you have pins with a teeny tiny collar on one end to hold it in. Those can get lost very easily, almost invisible to the eye. I do my work on a plush microfiber cloth that minimizes parts rolling or bouncing away. For some work, a cheap pair of jeweler's magnifier glasses is a great boon.
This could be the flatter style of bracelet with the interlocking sections. A pic of the back of the bracelet would help to identify it more accurately.
My study carpet has more spares than Cousins! :hypocrite:
Mike
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
UK Watch Forum
1.6M posts
54.2K members
Since 2003
A forum community dedicated to UK watch owners and enthusiasts. Come join the discussion about watch collections, displays, watch winders, accessories, classifieds, and more! We welcome all manufacturers including Casio G-Shock, OMEGA, Rolex, Breitling, Rolex and Tudor, Seiko, Grand Seiko and others.
